converting avid projects to final cut
hello all,
is there any way, when having to convert from an avid project to a final cut pro, to keep the project structure such as logged clips and snyced audio clips? Is automatic duck really any good if all it does if give you the timeline? And what about effect heavy timelines? How does it cope with these. Is the safest option just to start again from scratch using edls and restructure the entire project?
thanx
chris
