Activity › Forums › Compression Techniques › Converting avi using compressor
  • Converting avi using compressor
    Posted by James Bayliss-smith on December 3, 2010 at 4:06 am
    Hi there I’ve just received some archive footage that I would like to use in my documentary. They are all avi files. I’d like to use compressor to convert them for use in Final Cut Pro. I used an application called VideoSpec to check them out here is the report
    *** General Parameters ***
    – Name: INV184463.avi
    – Container: AVI – Audio Video Interleaved
    – Creation Date: 1904-01-01 08:26:44
    – Size: 55085.0 MiB
    – Duration: 0:34:33
    – Bitrate: 223 Mbps
    – Encoding Library: Undefined
    – Encoding Application: Undefined
    *** Video Track Parameters ***
    – Format: Apple FCP Uncompressed 10-bit 4:2:2
    – Size: 53.4 GiB (99%)
    – FourCC: v210
    – Track number(s): 0
    – Bitrate: Max.: Undefined
    Average: 221 Mbps
    Min.: Undefined
    – Frame rate (fps): Max.: Undefined
    Average: 25.000
    Min.: Undefined
    – Bitrate mode: Undefined
    – Encoding profile: Undefined
    – Resolution: 20 bits
    – Width (Pixel number): 720
    – Height (Pixel number): 576
    – Pixel Aspect Ratio: Undefined
    – Display aspect ratio: 5:4
    – Chroma subsampling format: YUV422p
    – TV standard: PAL
    – Interlacing: Undefined
    – Encoding library: Undefined
    – Additional Parameters: Bits/(Pixel*Frame) ratio: 21.333
    I imported them into FCP and I got the error message: The following media files are not optimised for final cut pro.
    My instinct is to convert them all to ProRes 422 using Compressor. Is this the way forward?
    If I convert them to ProRes422 should I up-res them to HD frmae size (albeit 4:3)?
    Should it be HQ?
    What is the Format: Apple FCP Uncompressed 10-bit 4:2:2?
    My ultimate use for them will be in and HD (HDV) documentary 16:9. I may crop them so they are 16:9 aspect ratio. All my footage was captured as DV but I will ultimately recapture all the tapes at ProRes422 1920×1080 for final post-production. I am also using some archive from a DVD. I have converted the DVD using MPEG Streamclip.
    Again should I up-res thee DVD footage if my ultimate project will be 1920 X 1080?
    I know that FCP can handle different formats in the timeline but I’m a little confused about the whole up-ressing business. I would say 95% of my documentary is HDV so I would like to make an HD version but I don’t understand how to properly use the SD footage, both archive and stuff I shot not in HDV
    Should I up-res the DV footage as well as the archive?
    Any help on any of these points would be much appreciated,
    All the best
    James Bayliss-Smith
    James Bayliss-smith replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
