Activity › Forums › Adobe Premiere Pro › converting avi to .dv file
Posted by Susan Johnson on August 2, 2007 at 7:37 pmDoes anyone know how to convert an avi file out of Premiere Pro to a .dv file that can be played on a Mac? I have tried pulling the avi file into QuickTime Pro and converting it using DV Stream, but it comes out fuzzy and low quality. Any ideas? I am deperate for an answer!!!!
Jeff Brown replied 19 years, 1 month ago 3 Members · 6 Replies -
Susan Johnson
August 2, 2007 at 8:48 pmI tried that as well. I exported it as an avi from Premiere Pro, brought it into QuickTime Pro and converted it to a QuickTime file and then converted the QuickTime file to a DV stream. It still look horrid. Any other suggestions? I am open to anything! My Procoding software does have the open to convert to a DV-AVI Type 1 and Type 2 file but that file still shows up as an avi. I need a good looking .dv file Help!
Blast1
August 2, 2007 at 9:04 pm[CourtneyVideo] “brought it into QuickTime Pro and converted it to a QuickTime file and then converted the QuickTime file to a DV stream”
Stop when you make the first QT file, there is no reason for further conversion, QT files play fine on a Mac.
Susan Johnson
August 2, 2007 at 9:18 pmI know, but my client needs to play it out of a special new version of Pro Presenter that only plays .dv files.
Blast1
August 3, 2007 at 8:44 amTo avoid the double conversion, output to tape and recapture on a Mac as .dv, it should be fairly lossless except for .dv
Jeff Brown
August 3, 2007 at 4:16 pmGo into QTime and change the playback settings for your rendered movie to “High Quality”. For some reason, on the PC, this is off by default, and my guess is that’s why the video looks horrid: you’re not seeing what’s really in the file.
-jeff
