Activity › Forums › Maxon Cinema 4D › converting an extruded nurb to polygons…. newbie question
  • converting an extruded nurb to polygons…. newbie question
    Posted by Joe Carusoe on June 15, 2005 at 6:30 pm
    ok.
    i’ve got an extruded nurb object with roundings on the caps. i want to convert the thing to poly’s so i can sketch + toon it without outlines on the cap seams.
    i converted the object by using ‘current state’ to it…. but the main body and the 2 caps are still seperate poly objects. how do i make all 3 parts one object?
    thanks!
    Brian Jones replied 21 years, 3 months ago 2 Members · 1 Reply
  • Brian Jones
    June 15, 2005 at 8:05 pm
    Select the pieces and do a Functions/Connect
    and (blindingly obvious but just in case) don’t forget to hide the originals
