Activity Forums Apple Final Cut Pro Legacy converting AAC audio to mp3
  • converting AAC audio to mp3
    Posted by Martin Knox on December 21, 2009 at 5:13 am
    I have video mp4 footage that is using AAC audio and I want to convert these clips to quicktimes that can be burned to a playable DVD disc. Whenever I attempt this, the audio file always goes missing when imported into DVD Studio Pro.
    How do I successfully convert these clips with AAC audio into editable video clips with attached audio in order to make them playable DVD’s?
    Thanks In Advance.
    2 x 2.66 GHZ Dual Core Intel 5GB 667 Ram
    OSX 10.5
    Rafael Amador replied 16 years, 8 months ago 3 Members · 3 Replies
  • Zane Barker
    December 21, 2009 at 5:19 am
    Well you DONT want to go to mp3.
    How are you trying to make this DVD?
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Martin Knox
    December 21, 2009 at 12:51 pm
    Dragging and dropping the the clip in Studio Pro from the the browser. When I lay the clip on the timeline the audio does not follow it.
    When I try to burn it a DVD using toast, toast does not recognize the audio either.
    OSX 10.5
  • Rafael Amador
    December 21, 2009 at 2:45 pm
    Hi martin,
    I think It shouldn’t be like that, but, while you find the reason, Open the clip in QT and export the audio as AIFF, then bring it to DVDSTP.
    rafael
    http://www.nagavideo.com
