Activity Forums Adobe After Effects Converting a simple black and white photoshop image to a mask in AE
  • Converting a simple black and white photoshop image to a mask in AE
    Posted by Andy Bay on February 22, 2006 at 4:28 pm
    Hello!
    I would like to some precise masking and I have a black and white image made in photoshop for that. How can I convert it to an editable mask in After effects (so that it behaves like it was made on the pen tool)? I also have Illustrator if that somehow helps the job? If anybody knows about this, I would be so happy if you could help me out!
    Aharon Rabinowitz replied 20 years, 6 months ago 2 Members · 3 Replies
  • Aharon Rabinowitz
    February 22, 2006 at 9:47 pm
    The auto Trace feature might be able to help you…
    Bring the photoshop image into AE, drop it into the comp, and then select the layer and try
    Layer > AutoTrace
    I think there are options in there for using luminance as the source of the trace, but if not there are definately settings for R G or B and since white is all RGB and black is no RGB, then it should work.
    If you can just get rid of the non-mask area in PS, then there’s also an option for using Alpha as the source of the trace.
    This tool creates a mask either on the layer, or on a new solid that perfectly 9or almost perfectly) matches your traced element.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Andy Bay
    February 23, 2006 at 12:07 pm
    Thank you very much! The auto-trace certainly seems like a helpful feature!
  • Aharon Rabinowitz
    February 23, 2006 at 1:42 pm
    I use it to create tight junk mattes around a footage I have to key. And a few other things I can;t think of due to lack of sleep. But all in a ll a nice tool.
    Aharon Rabinowitz
