Activity Forums Compression Techniques Converting a MP4 file to avi
  • Converting a MP4 file to avi
    Posted by Volker Bradley on April 7, 2012 at 8:30 pm
    I used my camera to make at video. I would like to convert this file to an avi file. What command would you suggest to make the avi file using ffmpeg and lame?
    The details of the file are:
    ffmpeg -i M4H00846.MP4
    ffmpeg version git-2012-01-06-ed14b72 Copyright (c) 2000-2012 the FFmpeg developers
    built on Jan 6 2012 10:54:37 with gcc 4.6.1
    configuration: –enable-gpl –enable-libfaac –enable-libmp3lame –enable-libopencore-amrnb –enable-libopencore-amrwb –enable-libtheora –enable-libvorbis –enable-libx264 –enable-nonfree –enable-postproc –enable-version3 –enable-x11grab
    libavutil 51. 34.100 / 51. 34.100
    libavcodec 53. 54.100 / 53. 54.100
    libavformat 53. 29.100 / 53. 29.100
    libavdevice 53. 4.100 / 53. 4.100
    libavfilter 2. 57.101 / 2. 57.101
    libswscale 2. 1.100 / 2. 1.100
    libswresample 0. 5.100 / 0. 5.100
    libpostproc 51. 2.100 / 51. 2.100
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from ‘M4H00846.MP4’:
    Metadata:
    major_brand : MSNV
    minor_version : 19595353
    compatible_brands: MSNVmp42isom
    creation_time : 2012-04-04 12:22:47
    Duration: 00:00:36.03, start: 0.000000, bitrate: 9093 kb/s
    Stream #0:0(und): Video: mpeg4 (Advanced Coding Profile) (mp4v / 0x7634706D), yuv420p, 1280×720 [SAR 1:1 DAR 16:9], 9026 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 30k tbc
    Metadata:
    handler_name : Video Media Handler
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 24000 Hz, mono, s16, 64 kb/s
    Metadata:
    handler_name : Sound Media Handler
    Volker
    Volker Bradley replied 14 years, 3 months ago 2 Members · 4 Replies
  • Stephen Dixon
    April 9, 2012 at 2:58 pm
    what do you want to do with the AVI?
  • Volker Bradley
    April 9, 2012 at 4:19 pm
    I would like to make the avi file accessible on the Web. I would like to have the video start playing before the file is fully downloaded and I would like to have file compressed as possible consistent with reasonable display.
  • Stephen Dixon
    June 12, 2012 at 1:10 pm
    Why use an AVI then. An MP4 is a much better bet.
    Stephen Dixon
    Editor, Animator, Motionographer
    Museum Victoria
  • Volker Bradley
    June 12, 2012 at 8:41 pm
    OK, I will try using the mp4 format.
    Do you happen to know if qt-faststart will work with MP4 files?
