Activity Forums Adobe After Effects Converting a layer to 3D via ExtendScript
  • Converting a layer to 3D via ExtendScript
    Posted by Krishna Moorthy on November 4, 2016 at 7:44 pm
    Hey,
    kindly help me out to use draft3d attribute in my script. I want enable 3D for a specific layer. I don’t know how to use the draft3d attribute.
    Thanks in advance!
    Walter Soyka replied 9 years, 10 months ago 2 Members · 6 Replies
  • Walter Soyka
    November 5, 2016 at 4:28 am
    [Krishna Moorthy] “kindly help me out to use draft3d attribute in my script. I want enable 3D for a specific layer. I don’t know how to use the draft3d attribute.”
    draft3d is an attribute of comps, not layers. To make a layer 3D, set its threeDLayer attribute to true.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Krishna Moorthy
    November 6, 2016 at 6:01 am
    Yeah, that’s the thing I wanted to do. How set the draft3d attribute to true for a precomp.
  • Walter Soyka
    November 7, 2016 at 3:59 pm
    [Krishna Moorthy] “Yeah, that’s the thing I wanted to do. How set the draft3d attribute to true for a precomp.”
    It’s pretty straightforward:
    // replace with your own comp reference
    myComp = app.project.activeItem;
    // Enable the Draft 3D switch for the comp
    myComp.draft3d = true;
    Walter Soyka
  • Krishna Moorthy
    November 8, 2016 at 12:12 pm
    Here is the exact thing which I wanted.
    compReference.layer(1).threeDLayer = true:
    Found this through Adobe After Effects Scripting Guide.
    Thank you Walter.
  • Krishna Moorthy
    November 8, 2016 at 12:13 pm
    Meanwhile, I want to know what is the usage of draft3d attribute. Kindly, explain.
  • Walter Soyka
    November 8, 2016 at 2:02 pm
    [Krishna Moorthy] “Meanwhile, I want to know what is the usage of draft3d attribute. Kindly, explain.”
    From https://helpx.adobe.com/after-effects/using/previewing.html :
    “Each preview mode provides a different balance between quality and speed for playback and for updating of images during interactions, such as when you drag a layer in the Composition panel or modifying a property value in the Timeline panel. Draft 3D and Live Update modes apply to all views of a composition. Draft 3D disables lights, shadows, and depth-of-field blur for cameras.”
    Walter Soyka
