Activity › Forums › Apple Final Cut Pro Legacy › Converting a DVCProHD sequence to SD using Quicktime in LETTERBOX
Posted by Dneira on March 16, 2007 at 4:08 pmI have tried many settings to convert a DVCProHD sequence using Quicktime Pro into SD in Letterbox format. No mattar what I do it only gives me an anamorphic version. Is there a way to achieve a letterbox sd version?
The Edit doctor replied 19 years, 6 months ago 5 Members · 4 Replies -
Zak Mussig
March 16, 2007 at 4:18 pmUSe FCP instead of Quicktime. Just make an SD sequence with whatever settings you like, but make sure the anamorphic box is unchecked in the sequence settings. Drop your DVCProHD sequence and it will be letterboxed.
Zak
John Pale
March 16, 2007 at 5:07 pmIn Quicktime Player,
Export/Movie to Quicktime Movie
Click Options:
Settings: Select 8 or 10 bit Uncompressed
Size; Select in pulldown menu NTSC 720 x486 4:3 (or PAL..you didnt specify)IF YOU DO NOT SET THE SIZE AS ABOVE, IT WILL NOT WORK CORRECTLY.
Check Box: Check Preserve Aspect Ratio
In Pulldown menu select: LetterboxWorks for me, anyway.
This may be better for you than dropping into an SD sequence in FCP, as suggested earlier, as you will not need the additional drive space for the render.
Stuart Ferreyra
March 16, 2007 at 9:15 pmAnothe option is:
– Create an SD timeline
– Drop all your HD footage
– Change the distort option of one clip to -30%
– Copy
– Select All
– Paste Attributes
– RenderIt takes more words and time to explain than the number of right clicks to do it.
Stuart Ferreyra
Timecode Multimedia
President
Santa Monica, CA 90025
https://www.timecodemultimedia.com -
The Edit doctor
March 16, 2007 at 9:59 pmFor the nitpicky I feel the distort setting is more appropriate set to -33.33 instead of 30.
