Activity Forums Apple Final Cut Pro Legacy Converting 720p + Beta timeline to ALL SD
  • Converting 720p + Beta timeline to ALL SD
    Posted by Phil Smith on October 15, 2009 at 3:48 am
    Hey all: long time browser, first time poster here…
    I apologize, but after searching the forums for a bit, I didn’t see this issue addressed. I’ll try to keep it as short as possible.
    My client presented me with both 720p (specifically the new JVC FCP format), and digibeta footage that needed to be edited into a single 720p piece that had all of the elements “SD safe” for broadcast. So, when building the graphics etc, I built wings for the project, made “frames” for the SD footage and made sure that I correctly laid in the SD footage so that it showed up properly when viewed on both SD and HD…
    Now, all of a sudden, they want to abandon ALL of the HD graphics and content, and switch to an SD ONLY piece.
    My question is this: What is the best way to convert the sequence(s) so that the SD content is at full resolution, and the HD content now “scales down” to a size that can be shown in the right aspect on SD? I’ve tried just loading in a new sequence preset, but changing from HD to SD seems to make things very grainy and nasty. Is there an easy way to move everything over?
    Thank you for your time,
    -Phil Smith
    Phil Smith replied 16 years, 11 months ago 3 Members · 6 Replies
  • Shane Ross
    October 15, 2009 at 4:10 pm
    [Phil Smith] “What is the best way to convert the sequence(s) so that the SD content is at full resolution, and the HD content now “scales down” to a size that can be shown in the right aspect on SD?”
    Well, using COMPRESSOR would be the best way. But then it would still be 16:9. Not sure how to make it CENTER CUT SD.
    [Phil Smith] “changing from HD to SD seems to make things very grainy and nasty.”
    Did you render the footage? Look at it on an external SD monitor? Never ever judge the quality on the computer monitor.
    Compressor seems to want to encode the ENTIRE image, no way to center cut. And from what I understand, SD is lower field first when it comes to interlacing, and HD is upper…but I might be wrong. Great help, huh?
    We are having to do that here, mix Uncompressed SD with XDCAM…output to be Digibeta. Still testing and working on the details.
    Shane
  • John Fishback
    October 15, 2009 at 8:12 pm
    You don’t mention if you have a Kona or similar I/O device. The Kona can downconvert to SD cropping the sides (or letterbox) as it does, so you can play out to your DigiBeta. Would that work?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Phil Smith
    October 15, 2009 at 11:39 pm
    Oh, I SO wish… unfortunately, given the spec that the client has given me, they will not accept any form of anamorphic (so no bars, even small ones), so I can’t really get away with shooting it through my Kona 3 and just down-converting on the fly. Would definitely be easier though.
  • Shane Ross
    October 15, 2009 at 11:44 pm
    Uh, in the AJA CONTROL PANEL you can either downconvert and output Anamorphic, Letterbox or CROP, meaning center crop. The Kona 3 can do this.
    Shane
  • Phil Smith
    October 15, 2009 at 11:50 pm
    Given that this footage was shot on the fly by their ENG guys, part of the issue that I’m dealing with is the noise in the blacks from the not completely well-lit area combined with the JVC/Apple codec. It only amplifies when converting this footage in the timeline.
    However, as an update for everyone, I may have found a workable solution.
    1) I created a new Sequence with the following settings:
    DV 3:2 aspect
    Progressive Frame
    No field dominance
    Apple ProRes 422HQ codec
    2) I then copied and pasted the footage from the HD sequence into the SD/DV timeline.
    3) I went back to the media, and Scaled to Sequence for everything (all 720p and Beta footage)
    4) On the 720p clips, I used “Noise Dissolve” on the footage, it got rid of a surprising amount of garbage. Then scaled them to ~70%
    5) Since the interviews that had noise were roughly all shot the same way, I then created a garbage matte over blank text as a transition layer and placed it over the area in the footage that was the problem.
    6) I added a gaussian blur at .25 pixels to the matted area. then adjusted the edge feather so that it created a pseudo-depth effect.
    It doesn’t look too bad after all that. Still wondering if anyone has the magic bullet though.. 😉
    -PJ
  • Phil Smith
    October 16, 2009 at 12:16 am
    Yes, I’m sorry… I should have mentioned. My client is a micro-managing “@$#%#$”… He looked at the crop, said no dice. The long process that I outlined gives almost the same result… loves it.
    (head-slap)
    Sigh… it’s not my money…
