Activity Forums Apple Final Cut Pro Legacy converting 720 x 480 to 720 x 486
  • converting 720 x 480 to 720 x 486
    Posted by Larry Watts on March 4, 2011 at 7:58 pm
    We are recording our 3 studio camera to our AJA KiPros at 720×486 Prores 422 at 702 x 486 full raster.
    We have a fourth field camera recording video onto a hard drive field recorder which records dvcpro at 720 x 480.
    I can convert the dcvcpro to apple Pro res 422 easily enough, but do not know how to add the additional lines of raster. I need to do this because plural eyes rejects the 4th camera as incompatible.
    Any ideas how to get 480 lines to 486 lines without copying it over in real time?
    Larry
    Larry Watts replied 15 years, 6 months ago 4 Members · 6 Replies
  • Chris Tompkins
    March 4, 2011 at 8:17 pm
    you should be able to drop the 720X480 clip into the 720X486 sequence easy enough without issue.
    If you do a FULL render on the vid b/4 the plural eyes sync – does that work?
    Chris Tompkins
    Video Atlanta LLC
  • Rafael Amador
    March 5, 2011 at 2:11 am
    [Chris Tompkins] “you should be able to drop the 720X480 clip into the 720X486 sequence easy enough without issue.”
    Right.
    FC will add those 6 extra lines.
    He know how to do it (I think was 2 on top and one in the bottom of each field).
    rafael
    http://www.nagavideo.com
  • John Pale
    March 5, 2011 at 5:07 am
    [Larry Watts] “I can convert the dcvcpro to apple Pro res 422 easily enough, but do not know how to add the additional lines of raster.”
    If you want to do this before putting it in FCP, you can drop it in Compressor, and set it to 720 x 486 in the Geometry Pane. Compressor will automatically add the proper padding to the top and bottom.
  • Larry Watts
    March 8, 2011 at 9:01 pm
    3 great ideas, and all work!
    I’ve already tried using compressor which is very easy and will work well.
    Thanks everyone!
    Larry
  • Larry Watts
    March 15, 2011 at 7:28 pm
    OOPS!
    After using compressor and the geometry pane the render went soft. It changed it to 486, though.
    When switching back and forth from the 486 created by the KiPro recorders to the newly rendered 486 ther was a size jump in the image. I don’t get that. I rendered to 422 without the geometry pane and the image stayed sharp.
    I’m not sure what happened, but I’m back to square one.
    Any ideas?
    Larry
  • Larry Watts
    March 15, 2011 at 7:30 pm
    Chris,
    Yes a full render to 486 before going into Plural Eyes worked.
    If you look at my recent post, I found out compressor made the video go soft.
    Not sure why.
    Larry
