Activity Forums Apple Final Cut Pro Legacy converting 5D footage to 24p
  • converting 5D footage to 24p
    Posted by Jeffrey Durkin on June 24, 2009 at 5:49 am
    Hello guys,
    I know this is covered quite a bit, but I’m confused by all the information out there.
    I have a 24 fps Pro-res 422 timeline in FCP, and need to convert footage from
    a Cannon mark II 5D to fit that format. I have compressor and cinema tools, what
    is the simplest way? I need to do the conversion to the original clips, so I can work
    then in with my other footage.
    Jeff
    Rafael Amador replied 17 years, 2 months ago 2 Members · 1 Reply
  • Rafael Amador
    June 24, 2009 at 6:07 am
    If you would go 30>29,98 the way would be to transcode to any Intraframe codec and then conforming with CinemaTools.
    But going 30> 24 Compressor is your way. Transcode and change the time-base at once.
    rafael
    http://www.nagavideo.com
