Activity › Forums › Apple Final Cut Pro Legacy › converting 4K
converting 4K
Posted by Ryan Murray on September 19, 2015 at 12:46 pmwhen you shooting 4k do you have to convert it down to 1080p so you could edit in post ? if so what program is best to use,and can that program be used for go pro 4k as well . And when your done and it’s time to export the footage , do you keep it in 1080p or you could convert it back to the original 4k footage
Shane Ross replied 10 years, 11 months ago 2 Members · 5 Replies -
Shane Ross
September 19, 2015 at 7:39 pmThis all depends on what you will be delivering. Are you delivering 4K? or 1080p?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Ryan Murray
September 21, 2015 at 1:47 pmI would guess i would be delivering in 4k . but what is the steps for both 1080 & 4k . i was told you can’t export in 4k is that true ?.
Shane Ross
September 21, 2015 at 2:30 pmAre you using FCP 7 or earlier? It will export 4K…but if you are delivering 4K, you might consider using Resolve. Use it to convert the footage to 1080p to edit, and then export an XML to relink to the masters.
But this is something you need to KNOW…you can’t guess. And who will be doing the finishing?
Shane
Little Frog Post
Ryan Murray
September 21, 2015 at 4:17 pmI’m using fcp 7 , also heard that MPEG is also good to convert the footage, that is what I use . Basically I have a GoPro and want to shoot 4K on a gh4 , whatever I shoot in 4K I would like to export it in 4K . The reason I said ” I guess” is because I was told just to export the footage in 1080p and the export for 4K wasn’t provided.
And I would be doing the finishing -
Shane Ross
September 21, 2015 at 7:01 pmIf you do offline/online editing…convert 4K to 1080…you need to do so in a way that will be able to track the metadata. MPEG STREAMCLIP won’t. And this is a VERY tricky prospect with an application that was discontinued 4.5 years ago…last updated 5 years ago. Using camera tech that came out after it was discontinued, so all the normal ways to offline/online within FCP aren’t available.
You might try editing 4K in FCP…but you need to convert the footage to ProRes 4444 4K, and then you need very VERY fast drives to store this on. Or you can use Resolve to convert the footage to proxy footage, edit, and then finish with Resolve (But you’ll have to buy that…the free version tops out at 1080p resolution).
Or you can look at alternate software for editing, like FCX or Premiere, but Premiere, if you edit full res native, requires vast resources like fast processor, lots of RAM, and high end graphics cards. FCX will make a proxie to edit…you edit…then it’ll relink to the master footage later.
YOu can do this with FCP 7…you just need a very fast RAID to do this at full res…or you need to add Resolve to the mix for offline/online.
Shane
Little Frog Post
