Activity › Forums › Compression Techniques › Converting 30p to 24p efficently and relatively quickly?
  • Eric Strand
    August 31, 2012 at 2:21 pm
    He’s saying to edit in 30p and reverse pulldown after you complete the edit. Why did you transcode to ProRes LT?
  • Aj Barber
    August 31, 2012 at 3:08 pm
    Thanks for the response. I need to work with other footage that is Apple Pro Res 24p – I’m trying to get the 30p to match it.
  • Eric Strand
    August 31, 2012 at 4:05 pm
    Oh got it. I would go back to the original DVCPRO clips and when you transcode to ProRes LT, add reverse telecine in Compressor.
