Activity › Forums › Compression Techniques › Converting 30 fps playable DVD to 24 fps Quicktime
  • Converting 30 fps playable DVD to 24 fps Quicktime
    Posted by Addie Donnell on December 11, 2012 at 6:40 pm
    So, this is a problem that I deal with quite a lot, but my usual work around is unavailable this time. I am given a 4×3 Letterbox DVD with a 30fps vis TC. I am suppose to take this picture and convert it to
    720 x 480
    23.98
    TC burnt in
    MJPEGA
    Every time I do it, there are duplicate frames, which obviously will not fly. My current process is, ripping the DVD with mpeg streamclip as a Apple ProRes 422, importing into FCP in a 23.98 sequence, putting VIS TC, exporting, then compressing with Mpeg streamclip to the appropriate specs. There are always duplicate frames. Is there a way to get around this problem?
    Any help would be amazing! Thanks!
    Addie Donnell replied 13 years, 9 months ago 2 Members · 2 Replies
  • Craig Seeman
    December 11, 2012 at 7:45 pm
    [Addie Donnell] “but my usual work around is unavailable this time.”
    What would that be?
    [Addie Donnell] ” am given a 4×3 Letterbox DVD with a 30fps vis TC. I am suppose to take this picture and convert it to
    720 x 480
    23.98″
    Is your source 23.98 in i59.94?
    You’d want to do a inverse telecine to properly remove the pulldown. The software doing that would have to properly detect the cadence of course. Telestream Episode might be able to do this.
  • Addie Donnell
    December 11, 2012 at 10:55 pm
    Usually, I have te CTM to marry to the M & E’s to export and compress, boom, done. But I don’t have that today. I will try and investigate Telestream Episode, I suppose.
    Thanks for you help.
