Activity Forums Compression Techniques converting 29.97 progressive HD to 59.94 interlaced for HDCam layoff
  • converting 29.97 progressive HD to 59.94 interlaced for HDCam layoff
    Posted by Christopher Burke on August 15, 2009 at 6:04 am
    I have a 1080p 29.97 sequence in final cut and have just learned that I need to deliver a 1080i 59.94 HDcam master. the project has to be rendered out and sent as a ProRes QuickTime to a closed captioning house, where the staff will insert the caption file and do the final layoff using a Matrox MX02. I know the Matrox is capable of doing a hardware frame rate conversion, but can anyone recommend the best way to create a file from a 29.97 progressive sewuence that will be at home in a 59.94 interlaced sequence?
    Christopher Burke replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
