Activity Forums Apple Final Cut Pro Legacy Converting 29.97 into 24fps
  • Converting 29.97 into 24fps
    Posted by Arthur Lunn on July 13, 2010 at 7:02 pm
    Hello and sorry for bringing this up- I am sure this question gets asked every few months.
    I purchased stock footage that is 29.97 fps and need to fit it into a 24fps timeline.
    Clearly have to use TC, perhaps the reverse telecine or simple conformation?
    Also is there a further step (e.g., plug-in) required to complete the process, to make it glass smooth?
    Thank you for your time and consideration.
    Michael Sacci replied 16 years, 2 months ago 2 Members · 1 Reply
  • Michael Sacci
    July 13, 2010 at 8:59 pm
    If you want quality you need to do it out side FCP.
    Options – Compressor with Frame Control turned on. (reverse telecine only works on footage that WAS 24p and then had 2:3 or 3:2 pulldown added to make it 29.97)
    Red Giant Frames
    https://www.redgiantsoftware.com/products/all/magic-bullet-frames/
    The process is not quick to get quality but you convert the footage before you bring it into FCP. In this case quality means encoding time.
