Activity Forums Avid Media Composer Converting 23.98 to 29.97
  • Converting 23.98 to 29.97
    Posted by Richard Boghosian on March 18, 2014 at 1:56 am
    Trying to take Nikon h.264 files shot at 23.98 to a 29.97 project. Can’t get a clean pull down conversion in Avid. Resorted to Adobe Encoder CC. The resulting files from Adobe were much smoother looking on an interlaced monitor than the conversion from within the avid. Any help with the right workflow for 23.98 to 29.97?
    Richard Boghosian
    Bogh AV Productions
    AVID 7.03 MacPro 2014 16Gb ram BMD Ultra 4K
    Michael Phillips replied 12 years, 6 months ago 3 Members · 5 Replies
  • John Pale
    March 18, 2014 at 2:34 pm
    Make sure the Field Order column is visible in the bin when AMA linking (that column is not on by default)
    If it says “unknown” instead of Progressive, it will not add the pulldown correctly.
    Select all in the column and right click to change to Progressive.
    Transcode your clips and the correct pulldown will be added .
    PS: just to be clear, I am advocating linking to the Nikon files via AMA, correcting the field order setting, then transcoding to Avid DNXHD files.
  • Richard Boghosian
    March 18, 2014 at 2:43 pm
    Thank you John. Yes, the field motion is reading progressive. In order to transcode to 29.97, I must open the bin in a 29.97 project correct?
    Richard Boghosian
    Bogh AV Productions
  • Michael Phillips
    March 18, 2014 at 11:46 pm
    Yes, open first in 23.976, then open that bin in a 29.97p or 29.97i as needed for your conversion.
    Michael
  • Richard Boghosian
    March 19, 2014 at 12:11 am
    This is exactly what I’ve done. The resulting clips on a 29.97 timeline are still not crisp, and suffer from judder. Conversely, the same Nikon h264 files converted in Encoder and imported onto the same 29.97 timeline look clear and very little judder in the fast panning shots.
    Richard Boghosian
    Bogh AV Productions
  • Michael Phillips
    March 19, 2014 at 12:53 am
    Interesting… I will do some tests on my end to see what the issue might be.
    Michael
