Activity › Forums › Apple Final Cut Pro Legacy › Converting 16:9 to 4×3
Posted by Ron Fenley, on October 1, 2012 at 7:56 pmWhats the best way to convert an HD project that was shot 16:9 with a 4×3 window for shot framing. Client want to put this in a 4×3 window on the internet.
Joseph Owens replied 13 years, 11 months ago 6 Members · 8 Replies -
Tony Brittan
October 1, 2012 at 11:49 pmDrop the finished 16:9 master into a 4:3 timeline and increase the scale until it fills the frame. Render and export. I would use a Prores 4:3 timeline.
Shane Ross
October 2, 2012 at 12:17 amNote: There is no such thing as 4:3 HD…so the timeline will pretty much have to be SD.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Tony Brittan
October 2, 2012 at 12:22 amSorry…I guess I assumed they knew that Shane 🙂 But yea…that’s why I suggested Prores…at least it’ll be better than NTSC.
Ron Fenley,
October 2, 2012 at 12:29 amHaven’t shot it yet. Was considering just shooting the 42 spots all in SD and call it a day but I’m shooting with white background and using luminance key to swap out the white bg with white slug. Works good in HD. Not so good in SD.
Really appreciate the advice. Think I want to let their web guys worry about the 4×3 conversion. Knuckleheads. I’m supposed to start shooting tomorrow and they just told me about the 4×3 stuff. Thanks again my friend. I owe you one.
— ron
Phil Smith
October 2, 2012 at 1:07 amI believe what you are looking for is “Apple ProRes 422 NTSC 48 kHz”. Once you pick that setting, you should see the frame size of your sequence change to 720 x 486. Good luck!
Phil Smith
There are no technical solutions to creative problems. Only creative solutions to technical problems. -
Jeff Meyer
October 2, 2012 at 3:37 amIf it’s going to web wouldn’t 640×480 (or better yet – the final video size) using a square pixel aspect ratio be the correct choice?
Joseph Owens
October 2, 2012 at 3:15 pm[Jeff Meyer] “If it’s going to web wouldn’t 640×480 (or better yet – the final video size) using a square pixel aspect ratio be the correct choice?
“Yes, you’re in for a world of hurt now.
You want to be hexadecimal compatible (everything divisible by 16) if you want a clean web presence. So you will likely wind up in a 480P format, whatever the pixel aspect ratio might be that you negotiate and finally cram into the “standard” NTSC frame.
jPo
“I always pass on free advice — its never of any use to me” Oscar Wilde.
