Activity › Forums › Apple Final Cut Pro Legacy › converting 16:9 to 4:3 letterbox Edge flicker
  • converting 16:9 to 4:3 letterbox Edge flicker
    Posted by Mahmoud Abdulsamie on July 4, 2009 at 8:00 pm
    Hello
    i have a problem with converting 16:9 footage to 4:3 letter box i get edge flicker on my broadcast monitor.
    here is what i am doing in detail.
    The footage i have is shot in 16:9 on a Digibeta DVW-970 then edited on a sony linear editing system in 4:3.
    what I am asked to do is to squeeze the picture to correct the Aspect ratio.
    I captured the Material in Blackmagic Pal-10bit
    put the footage in to the timeline and distort it in to -33.33
    the result is as desired except that the footage is flickering at the top and bottom edges only on my preview monitor (Sony BVM-2010P ColorMonitor (PAL).
    I tried cropping the edges but i still get the same problem.
    What should i do.
    Thanks in advance…
    Mahmoud Abdulsamie replied 17 years, 2 months ago 3 Members · 4 Replies
  • John Fishback
    July 4, 2009 at 8:55 pm
    When you say you’re editing in 4×3 with your Sony edit system are you seeing an anamorphically squeezed image on your monitor? If so, when you capture that in FCP it should remain anamorphic. When you play it, with the Sequence Setting for anamorphic checked, it should be 16×9 on your monitor. You should also check in the Browser that the anamorphic field (scroll right) is checked. You don’t say what the final output should be. But, usually, the player will adjust the image to 16×9 or 4×3 with letterbox automatically.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Mahmoud Abdulsamie
    July 4, 2009 at 9:22 pm
    Dear John
    thanks for the reply the footage on the digibeta is stretched in 4:3 not in the right aspect ratio,,, the result should be letterbox 4:3 i.e i need to distort it to -33.33
    hope that explains more
    thanks
  • Arnie Schlissel
    July 4, 2009 at 10:55 pm
    [Mahmoud Abdulsamie] “thanks for the reply the footage on the digibeta is stretched in 4:3 not in the right aspect ratio,,, the result should be letterbox 4:3 i.e i need to distort it to -33.33”
    I don’t think you understand John’s post. If you check the anamorphic box for a clip in the FCP browser, then drop it into a 4×3 sequence, it should be automatically letterboxed for you, without having to set the distort tab to -33.33.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
    July 5, 2009 at 8:16 am
    Thanks Arnie
    I do understand Johns post but the issue is not how it should be done the issue is the flickering on the top and bottom of the image a i tried johns way but still the same issue i also tried clopping still the same issue..
