Activity Forums Apple Final Cut Pro Legacy converting 1080/1440 .mov to quality small size 16 x 9 file
  • converting 1080/1440 .mov to quality small size 16 x 9 file
    Posted by Peter Hall on April 2, 2011 at 8:47 pm
    I’m attempting to transcode a 700MB 1080 x 1440 mov file to a smaller file that maintains the 16 x 9 aspect and reasonable quality in a file under 100MB – so far I’m getting crappy results via FCP 7 export using Quicktime Conversion – check on maintain 16 x 9 aspect doesnt maintain 16 x 9.. any suggestions for a quality conversion I can send over Yousendit? Compressor or MPEG streamclip?
    Any suggestions are much welcome.
    Peter Hall
    Peter Hall replied 15 years, 5 months ago 2 Members · 6 Replies
  • Steve Eisen
    April 2, 2011 at 9:42 pm
    Exporting using QuickTime Conversion is your problem.
    Export a QT Movie select self contained if you want a master copy of your project.
    Drop that file into compressor and choose an h.264 setting for your liking.
    a example would be h.264 800kbs. If you want a higher bit rate, change your data rate.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Peter Hall
    April 2, 2011 at 9:49 pm
    Thank you Steve, I shall try Compressor. Any clues to the algorythms of kbs in relation to MB size of original file? About to go fishing in Compressor. Cheers.
    Peter Hall
  • Steve Eisen
    April 2, 2011 at 10:39 pm
    Compressor will give you an estimated size. The higher the data rate, the higher the quality and larger the file size. I would not go over 5,000 kb
    Steve Eisen
    Vice President
  • Peter Hall
    April 2, 2011 at 11:18 pm
    Steve, please forgive my ignorance, but I am not seeing options for kb speed in Compressor, only different codecs. The first H264 1K version I tried gave me a 25k file that was 4/3 in aspect. I’m now trying a new H264 setting that promises to respect my original quicktime .mov settings, At this point I’m keen to get the 16 x 9 replication in a low rez file.Thanks for your patience.
    Peter Hall
  • Steve Eisen
    April 3, 2011 at 2:57 am
    Click on the Help tab inside Compressor and find the User Manual.
    Search for this:
    Customizing MPEG-4 Video Settings
    Steve Eisen
    Vice President
  • Peter Hall
    April 3, 2011 at 11:47 pm
    Thank you Steve, will follow that path, many thanks. Peter
    Peter Hall
