Activity Forums Apple Final Cut Pro Legacy Converted files jaggy!
  • Converted files jaggy!
    Posted by Russ Carlin on March 8, 2012 at 2:08 pm
    Hi all, my sequence in FCP is a progressive sequence and the 720p footage looks as it should, but my 1080i footage is very jaggy. The reason i’m posting is because i’ve converted all the footage to pro res 422 using mpeg streamclip and the 1080i footage has no field dominance. so any ideas why it is jaggy?
    Could it be because i’m only viewing it on my imac and not a monitor? I’m sure i had a similar problem before but it was just down to not viewing it on a monitor, but thought i may as well check it out on here!
    Cheers!
    Russ
    Carrrrrrr Carrrrrrrrrrrrr
    Russ Carlin replied 14 years, 6 months ago 2 Members · 2 Replies
  • Shane Ross
    March 8, 2012 at 5:45 pm
    Interlacing doesn’t display properly on computer displays. You need external monitoring that can do interlacing in order to see that things are good.
    Shane
    Little Frog Post
  • Russ Carlin
    March 9, 2012 at 11:36 am
    Cheers Shane, thought it may be that!
    Russ
