Activity › Forums › Apple Final Cut Pro Legacy › convert uncompressed 10bit Quicktime file to DV codec (after telecine)
  • convert uncompressed 10bit Quicktime file to DV codec (after telecine)
    Posted by Khashyar Darvich on December 20, 2006 at 6:13 pm
    Hi Everyone,
    I am having about 6.5 hours of old 8mm film transfered to probably uncompressed 10bit Quicktime files (using a Cintel rank telecine at Cinepost in Georgia).
    The project that the 8mm footage will be used for will have a dvcam sequence format. (I am saving the film to 10 bit uncompressed in case I want to use it in the future in an uncompressed sequence).
    My question is is it easy to convert the 10 bit uncompressed Quicktime files to dv codec Quicktime files?
    I know that I could import the uncompressed files into the DV sequence and then render them, but I would rather convert the 10bit files to DV and import and use the DV version of those files.
    Would I simply do this through creating a separate 10bit sequence in FCP, and then export the sequence as a DVcam Quicktime file?
    I am working with a Quad-core Mac (with 4 GB RAM) and FCP 5.2, so I am assuming that my computer can handle the uncompressed files.
    I am also worried about the 4th flame jitter that I have read sometimes occurs with telecines… Any advice as to what I should tell the telecinist at Cinepost to eliminate the potential frame jitter?
    Thank for your input about the best conversion method.
    Khashyar
    Khashyar Darvich replied 19 years, 9 months ago 2 Members · 3 Replies
  • Khashyar Darvich
    December 20, 2006 at 7:13 pm
    Any feedback would be appreciated.
    I have the option of have the telecine captured using an uncompressed 10-bit format, or a dv codec.
    I haven’t converted a 10bit Quicktime file to a DV Quicktime file, so I would like to make sure that FCP can easily convert 10bit before I give the go-ahead for the uncompressed telecine.
    Thanks for your feedback,
    Khashyar
  • David Roth weiss
    December 20, 2006 at 9:56 pm
    Go ahead and do it. You can simply use QT conversion or Compressor to convert each file to DV.
    DRW
  • Khashyar Darvich
    December 20, 2006 at 10:02 pm
    Thank you very much, David.
    I have always either worked in an all DV sequence, or an all SDI sequence, and never converted one to the other.
    Thanks again,
    Khashyar
