Activity Forums Maxon Cinema 4D Convert to spline
  • Convert to spline
    Posted by Elie001 on October 18, 2007 at 2:38 pm
    I have splines used in the EXTRUDE NURBS object.I selected the three splines in the OBJECT MANAGER and drag and drop them, while holding the CTRL key, to another place in the OBJECT MANAGER in order to copy them .
    How can i convert the three spline copies, into normal splines.
    Thx in advance.
    Brian Jones replied 18 years, 11 months ago 2 Members · 1 Reply
  • Brian Jones
    October 19, 2007 at 1:22 am
    Normal splines? What do you mean? Are they parametric splines (like the circle or arc) and you want to make them editable? If so, right-click on the slpine and choose Make Editable or select the spline and press the “c” key.
