Activity › Forums › Apple Motion › Convert to Key Frames
  • Convert to Key Frames
    Posted by Hmvideo on January 13, 2006 at 12:46 am
    I have some text that I’d like to bounce off the top of the frame and bring to a stop about a third the way back down. I appled a few behaviors (throw, edge collide, drag), but the text still goes a bit past the top of the frame. I’d like to convert the whole thing to key frames and tweak it in the key frame editor. I select the text and go to the Object menu, but the Convert to Key Frames choice is grayed out. Any ideas how to convert these behaviors? Many thanks!
    Doyle Rockwell replied 20 years, 8 months ago 2 Members · 1 Reply
  • Doyle Rockwell
    January 13, 2006 at 5:31 am
    Heya,
    Do you have Affect Objects enabled on any of those behaviors? If so, Convert To Keyframes won’t work. I’m not sure of all the reasons behind this, but since those behaviors could cause individual letters to move around and you can’t keyframe individual letters, it does make some sense. Hope this helps!
