Activity Forums Adobe After Effects Convert to edible text is greyed out
  • Convert to edible text is greyed out
    Posted by Robin Zweers on December 16, 2019 at 1:49 pm
    Hi guys
    A learning AE-user here. I am trying to make this lower third in After Effects. Everything works fine except the fact that I can’t convert my text to edible text. I tried to find an answer on google, but I couldn’t find it. So, does anybody of you know?
    Walter Soyka replied 6 years, 9 months ago 2 Members · 1 Reply
  • Walter Soyka
    December 16, 2019 at 6:38 pm
    Your text is already editable. If you want to change it, select the Type tool in Ae (Ctrl+T on Windows, Cmd+T on macOS) and then click into the text layer in the viewer panel, or double-click the text layer object in the viewer panel with the normal selection tool.
    The “Convert to editable text” command in the layer context menu is for use with imported Photoshop layers. If you import a PSD as a composition, you can use the “Convert to editable text” command on the footage layers which contain text to create native text objects (that no longer refer to the source layer in the PSD). More here if you’re curious:
    https://helpx.adobe.com/after-effects/using/creating-editing-text-layers.html#convert_text_from_photoshop_to_editable_text
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
