Activity › Forums › Adobe Photoshop › convert sq. pixel logo to 720×480 non sq.
  • convert sq. pixel logo to 720×480 non sq.
    Posted by Jack Blandford on April 21, 2007 at 5:28 pm
    I have a logo that was given to me. a psd file in square pixels.
    I’m trying to convert it so that it can be used in a fcp 720.480 sequence.
    Everytime I try to bring it in it has jagged edges. please help
    thanks jack
    Darby Edelen replied 19 years, 5 months ago 2 Members · 1 Reply
  • Darby Edelen
    April 22, 2007 at 4:17 am
    Well the problem with going from Square Pixels to 0.9 Pixels is that you’ll lose resolution either way you go. That said your options are as follows:
    1) Change the Image Size of the document to 111% width and 100% height. At a 0.9 Pixel Aspect Ratio your document will appear to be 111 * 0.9 = 99.9% of its original width.
    2) Create a new Photoshop document using the NTSC DV preset (720×480 0.9 PAR). Make sure Pixel Aspect Ratio Preview is on. Shift drag the layers from your Square Pixel document into the NTSC DV document, they should automatically adapt to the new PAR.
