Activity Forums Apple Final Cut Pro Legacy Convert Spreadsheet to .stl file
  • Convert Spreadsheet to .stl file
    Posted by Lucy Moon on August 12, 2011 at 11:04 am
    Hi All.
    Bit off topic FCP-wise, and I did look for this question being answered before but not much joy.
    Since an .stl file is so simple… and I have simple translation/subtitle csvs, of the format
    01:10,01:30,This is my text
    How do I convert this to…
    00:01:10:00 , 00:01:20:00 , this is my text
    Any ideas? Surely other people need this too?
    Cheers
    Astrid
    James Weber replied 15 years, 1 month ago 2 Members · 1 Reply
  • James Weber
    August 12, 2011 at 8:18 pm
    Your best bet would be to make the timecode correct within the spreadsheet, using the concatenate function, most likely. Then, you could export a csv, open it in a text editor, and, do a find and replace to add any consistent spaces or symbols.
    Final Cut tutorials from around the web- all in one place.
    https://www.fcptutorials.com
    https://www.jamesnweber.com
