Activity Forums Adobe Premiere Pro Convert Sequence to Multicam
  • Convert Sequence to Multicam
    Posted by Mark Palmos on November 3, 2016 at 2:11 pm
    Hello all, long time no see!
    EDIT
    Found solution:
    1. Create a sequence to hold your footage. (Source Sequence)
    2. Add the clips, and sync them manually.
    3. In the bin, right click that sequence and choose New Sequence From Clip. (Target Sequence.)
    4. In the timeline, right click on that newly nested sequence and choose Multi-Camera>Enable.
    I was thinking that enabling the Multicam Program viewer was the same as step 4… but it is not, you HAVE to R-mouse click on sequence and choose Multicam>enable.
    tx
    Mark
    Terry Syndergaard replied 5 months, 3 weeks ago 6 Members · 6 Replies
  • Rui Diogo
    September 6, 2017 at 9:21 am
    Hello,
    I have a project recorded in 3 cameras.
    I already placed the files into the sequence into 3 different tracks, and synced them.
    The problem is that each camera separated the video in 5 ou 6 different files.
    I already nested the files in each track so I have only one “file” for each track.
    My problem is that when I do the multicamera sequence, I loose the sync (because the in point is different on the 3 cameras).
    How can I avoid this? How can I sync the 3 tracks (nested)?
    Thank you very much!
    Rui
  • Jeff Herring
    June 23, 2018 at 8:05 pm
    Thanks Mark, This is exactly what I was looking for!
  • Jeff Herring
    June 23, 2018 at 8:07 pm
    Rui, I realize this is about a year too late for a reply, but, have you tried to highlight the separate clips. (or timelines) and tell it to sync using the Mixdown on the audio channels? That’s what I had to do with a project I’m working on now.
    Jeff
  • Kayo Torres
    November 19, 2019 at 9:43 pm
    Three years later and this post still rocks. Thank you so much, Mark!
  • Stefanie Link
    October 15, 2020 at 8:03 am
    Thank you!
  • Terry Syndergaard
    March 13, 2026 at 6:06 pm
    and 5. In Program Monitor select wrench tool and Multi-Camera. You may be in Composite mode.
