Activity › Forums › Adobe After Effects Expressions › Convert Selected Keyframes to Markers with custom label(marker color)
  • Convert Selected Keyframes to Markers with custom label(marker color)
    Posted by Eva Boe on July 17, 2023 at 5:39 pm
    I want a slightly modified version of the in-built script Convert Selected Properties to Markers.jsx.
    I want the markers created to be color Red for example and the marker comment to be empty and duration 0:00:00:00.
    I used chatgpt and provided me with this;
    var selectedProperty = app.project.activeItem.selectedProperties[0];
    var markerStream = selectedProperty.propertyGroup(1).property(“Marker”); // Get the marker stream of the selected property
    for (var i = 1; i <= selectedProperty.numKeys; i++) {
    var keyTime = selectedProperty.keyTime(i);
    var markerValue = new MarkerValue(“”); // Empty comment
    markerValue.label = 14; // Set the marker’s label color to red (index 14)
    markerStream.setValueAtTime(keyTime, markerValue);
    but when run the scriptlet (using Kbar > Run Scriptlet), I get the error
    “unable to execute script at line 11. null is not an object”
    Please help me. 🙏🙏
    Brie Clayton replied 3 years, 2 months ago 3 Members · 9 Replies
  • 9 Replies
  • Dan Ebberts
    July 17, 2023 at 6:46 pm
    Something like this maybe:
    function ConvertKeyframesToMarkers(){
    var comp = app.project.activeItem;
    if (! comp || ! (comp instanceof CompItem)){
    alert("No comp active.");
    return;
    var props = comp.selectedProperties;
    var prop;
    var layer;
    var marker;
    var markerVal = new MarkerValue("");
    markerVal.label =1; // red
    for (var i = 0; i < props.length; i++){
    prop= props[i];
    layer = prop.propertyGroup(prop.propertyDepth);
    marker = layer.property("Marker");
    if (! (prop.propertyType == PropertyType.PROPERTY)) continue;
    for (var j = 1; j <= prop.numKeys; j++){
    marker.setValueAtTime(prop.keyTime(j), markerVal);
    ConvertKeyframesToMarkers();
  • Eva Boe
    July 17, 2023 at 8:18 pm
    Thank you very much Mr. Dan. Worked perfectly.
    While I have you, I’m working with this expression below to use marker’s index to count the number of markers and put in “Offset” value with a little easing.
    I want the value to start from 0 every time there is a marker with empty comment.
    // Check for markers
    numMarkers = marker.numKeys;
    // Assign value to marker index with easing
    if (numMarkers > 0) {
    nearestMarkerIndex = marker.nearestKey(time).index;
    markerTime = marker.key(nearestMarkerIndex).time;
    if (markerTime > time && nearestMarkerIndex > 1) {
    prevMarkerTime = marker.key(nearestMarkerIndex - 1).time;
    t = (time - prevMarkerTime) / (markerTime - prevMarkerTime);
    markerIndex = nearestMarkerIndex - 1 + ease(t, 0, 1, 0, 1);
    } else {
    markerIndex = nearestMarkerIndex;
    } else {
    // No markers, set markerIndex to 0
    markerIndex = -1;
    // Use marker index value
    markerIndex;
  • Dan Ebberts
    July 17, 2023 at 10:57 pm
    I’m not exactly sure what you’re after, but this is how I’d calculate how long it’s been since the last marker with no comment:
    m = marker;
    t = 0;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (time < m.key(n).time) n--;
    if (n > 0){
    for (i = n; i > 0; i--){
    if (m.key(i).comment == ""){
    t = time - m.key(i).time;
    break;
    t
  • Eva Boe
    July 18, 2023 at 4:04 am
    Yeah… something like this.
    The expression you provided works but it starts counting from .1 but I want to ease into 1 (first marker) and then 2 (second marker) etc.
  • Dan Ebberts
    July 18, 2023 at 5:08 am
    Something more like this maybe:
    m = marker;
    easeTime = .25;
    n = 0;
    if (m.numKeys > 0){
    n > 0 ? ease(time,m.key(n).time,m.key(n).time+easeTime,n-1,n) : 0
  • Eva Boe
    July 18, 2023 at 10:59 am
    No, not really.
    I want the empty markers to act like a “reset button” so the value starts with 1 at the marker after the empty “red” markers.
    Is that possible?
  • Dan Ebberts
    July 18, 2023 at 2:22 pm
    Ah, sorry, forgot that part. Try this:
    m = marker;
    easeTime = .25;
    n = 0;
    if (m.numKeys > 0){
    temp = n;
    c = 0;
    while (temp > 0){
    if (m.key(temp).comment == "") break;
    c++;
    temp--;
    c > 0 ? ease(time,m.key(n).time,m.key(n).time+easeTime,c-1,c) : 0
  • Eva Boe
    July 18, 2023 at 2:51 pm
    Thank you once again Mr. Dan.
  • Brie Clayton
    July 18, 2023 at 4:07 pm
    Thank you for your solve, Dan!
