Activity Forums Adobe After Effects Expressions Convert project from 30 fps to 23.976
  • Convert project from 30 fps to 23.976
    Posted by Jake Nelson-dooley on February 29, 2012 at 9:09 pm
    I asked something about this in a previous post (https://forums.creativecow.net/readpost/227/20388) but I think I got ahead of myself.
    But I think I made a mistake by getting into specifics. So instead here’s the general question:
    I’m converting a project that was animated at 30 fps to 23.976 fps. Once the compositions are set to the new frame rate, the keyframes are slightly off. They don’t sit exactly on a frame. Is there any way to automate the process of fixing this? Or is there a better way to convert b/w frame rates? Seems after effects is a bit crude about it…
    Jake Nelson-dooley replied 14 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
