Activity › Forums › Maxon Cinema 4D › Convert older C4D file to use in R26
Posted by Kevin Bolyard on August 15, 2024 at 4:55 pmI have an older file that I need to open in my current version of C4D. I don’t have any versions before R20.
Is there anything out there from Maxon to convert older files?
Cheers,
Kevin
Kevin Bolyard replied 2 years, 1 month ago 2 Members · 4 Replies -
Kouraib Abdmalek
August 16, 2024 at 5:36 amHi Kevin,
You could post your file here or send it via email and I’ll convert it for you.
Kevin Bolyard
August 16, 2024 at 10:04 pmThank you very much. I really appreciate it. There are actually two files that would really help.
Here you go… 🙂
Kouraib Abdmalek
August 17, 2024 at 9:49 amI was able to convert the first file, but I had a problem with the second one.
Kevin Bolyard
August 19, 2024 at 5:33 pmThis is perfect. I can just work with this and build the rest from scratch.
Can’t thank you enough. Very cool!!!🙂
Kevin
