Activity Forums Avid Media Composer Convert MXF to Quicktime
  • Convert MXF to Quicktime
    Posted by Uli Kunkel on December 3, 2009 at 12:04 am
    I am digitizing HDCAM footage into Media Composer, but I’ll be needing to eventually take it to a Final Cut system for editing. What is the best way of doing the necessary conversion? I don’t have automatic duck.
    Terence Curren replied 16 years, 9 months ago 2 Members · 3 Replies
  • Terence Curren
    December 3, 2009 at 1:34 am
    Export as a Quicktime movie from the Avid.
    Why aren’t you capturing into FCP to save the trouble?
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Uli Kunkel
    December 3, 2009 at 4:56 pm
    I can export as quicktime from Avid, but I was concerned that if I did that I would lose the original tape timecode in the exported QT file. Do you know if I will?
    I’m not digitizing directly into FCP because I don’t have a deck connected to an FCP system at my disposal. If I digitize into Avid, I don’t have to rent a deck for 1 tape.
    Thank you for your help.
    Uli
  • Terence Curren
    December 3, 2009 at 5:09 pm
    Got it.
    Yes, MC does export timecode, but only in the newer versions. I don’t remember if this came in 3.5 or 4.0.
    For future reference (and a guilty plug) you might check out https://www.digitalservicestation.com/ which is set up to handle exactly your type of situation.
    Terence Curren
    Burbank,Ca
