Activity Forums Adobe Photoshop Convert multiple path points at once
  • Convert multiple path points at once
    Posted by Matt Hopkins on August 16, 2016 at 7:50 pm
    Is there a way to convert a bunch of selected points at one time?
    I’m working with a distressed font, which I am turning into a Work Path. I need to convert all the points from smooth to corner. I’m hoping there is a quick way that doesn’t require me to click on each point.
    Matt
    Matt Hopkins replied 10 years, 1 month ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    August 16, 2016 at 8:51 pm
    Online manual: “To convert one or more smooth points to corner points, select the points and then click the Convert Selected Anchor Points To Corner button in the Control panel.”
    https://helpx.adobe.com/illustrator/using/editing-paths.html
    Edit: Oops, sorry, that’s Illustrator, but if you have Illustrator, you could copy them to Illustrator for conversion and back to PS.
    Senior Graphic Designer
  • Matt Hopkins
    August 16, 2016 at 9:21 pm
    Thanks Kalle. I’m a pretty light Illustrator user, but I’m kicking myself in the pants for not checking to see if I could do it there. Good call.
    Matt
