Activity › Forums › Adobe Premiere Pro › convert .MTS to use in Premiere Pro cs3 on pc
  • convert .MTS to use in Premiere Pro cs3 on pc
    Posted by Jasper Lassilaakson on June 1, 2011 at 10:38 am
    Hello !
    I have some .MTS files that I need to edit in premiere Pro cs3 on a Windows PC, and I have been downloading several mts converter trials, and they all place a watermark on the converted file. Before I am going to purchase one of the converters to avoid these stupid warermarks.. I wondered if anyone knows what converter is a good one to use, and into what I should convert these files ?
    Thank you !
    Bob Coker replied 13 years, 11 months ago 6 Members · 9 Replies
  • 9 Replies
  • Ann Bens
    June 1, 2011 at 5:24 pm
    I tried several converters and like NeoScene the best.
    https://www.cineform.com/neoscene/
  • Alan Lloyd
    June 4, 2011 at 9:59 pm
    Any Video Converter will do this and it’s free.
  • Ann Bens
    June 5, 2011 at 9:57 am
    I agree but will it keep the quality……..
  • Alan Lloyd
    June 6, 2011 at 3:02 pm
    If you set a high enough bitrate I don’t see why not.
  • Chris Knight
    June 30, 2011 at 4:57 am
    If you’re running Windows 7, you can edit MTS natively in CS3, but you need the CS3 Mainconcept plugin for Premiere to import the files. If they still have it available for download, it would be here:
    https://www.mainconcept.com/products/apps-plug-ins/plug-ins-for-adobe/mpeg-pro-hd-cs-4/h264avc-mpeg.html
    30 Day trial should be long enough to let you decide if the solution works.
    There’s also a very convoluted way of doing this through AVISynth, where Premiere will remotely access the footage through an external decoder. It works, but requires a lot of steps to get it working properly. Instructions for this are here:
    https://forum.videohelp.com/threads/273967-Editing-AVCHD-in-Premiere-without-intermediate-codec
  • Halvdan Dimor
    June 1, 2012 at 10:16 am
    Hi!
    I have Premiere Pro CS3, Win7 and using MTS-files (AVCHD).
    I have installed the latest Mediaconcept plugin (DEMO v 4.1.1), but when importing the file, the sound/audio is gone after a couple of minutes.
    I don’t know if this is due to that I’m using a demo version, but I haven’t heard of this limitation.
    Anyone know any advice?
    Or maybe a recommended MTS to Premiere-recognizable format tool?
  • Halvdan Dimor
    June 1, 2012 at 4:51 pm
    Hi!
    I have Prem Pro CS3, Win7 and using MTS-files (AVCHD).
    Or maybe a recommended MTS to Premiere-recognizable format?
  • Bob Coker
    October 9, 2012 at 8:12 pm
    Hey Chris: This was a very helpful post you made. I downloaded this convert program and it worked perfectly except for one problem. If I had an .mts file where the video clip was more than 30 seconds long, it would drop the audio after the inital 30 seconds. It would come back with each new file but again drop off if the clip was more than 30 seconds. Any idea what I am doing wrong?
    Bob Coker bob@bobcoker.com
  • Bob Coker
    October 10, 2012 at 2:19 pm
    When I used this convert program it would drop the audio of those files where the video was longer than 30 seconds. It would have 30 seconds of audio and then drop all audio after that until the next clip or file started.
