Activity Forums Adobe Audition convert mono to stereo
  • convert mono to stereo
    Posted by Mark Aitken on December 21, 2020 at 5:12 pm
    I need to convert mono files to stereo in audition. I’ve looked everywhere and it’s not happening for me. when i go into the waveform and convert it stays mono on the multitrack timeline. Surely this should be an easy thing to do? Latest version…
    Sean Platt replied 5 years, 8 months ago 3 Members · 4 Replies
  • Bruce Grieve
    December 21, 2020 at 5:38 pm
    My version is 3.0 but what works for me is when I am in the Multitrack tab, I slide a song (that is in mono) into the multitrack which is set as stereo, Adobe will convert it to stereo after you choose the settings you want I use 41000, 16bit and stereo. It creates a stereo cut of that song.
  • Mark Aitken
    December 21, 2020 at 5:42 pm
    Thanks Bruce. I can’t find the settings for the multitrack that point to stereo but what I need is something like they have in premiere where you can select a clip and simply convert. I can’t understand why it’s so complicated…
  • Bruce Grieve
    December 21, 2020 at 6:06 pm
    Well I have only used 3.0 given to me by the radio station I do a show for, it’s been 3 years now and I am still learning little tricks along the way, it can be frustrating for sure. Wish I could afford to upgrade but then again maybe I am better off using what I have, do not want a new steep learning curve.
  • Sean Platt
    January 5, 2021 at 4:01 pm
    Mark, did you ever find an answer to this? I am having same issue 🙂
