Convert Media 100 files to Quicktime or ProRes
Posted by James Kirk on July 15, 2007 at 6:53 pmHow can I convert Media 100 codec files to either Quicktime or Apple’s new ProRes 422?
Andrew Mehta replied 19 years, 1 month ago 6 Members · 8 Replies -
Abercrombie Pupputnick
July 15, 2007 at 10:20 pmUmm, Media100 media files ARE QuickTime. Can you tell us what you’re trying to do with the files?
James Kirk
July 15, 2007 at 11:04 pmI want to take Media 100 video files I digitized, that I cannot re-digitize, and edit the video within FCP 6.
It’s my understanding that the Media 100 codec is not directly playable as a Quicktime file. I’ve not been able to play these files as if they are Quicktime files. -
July 16, 2007 at 11:37 amDepending on what rev your M100 software is, the Media100 codecs since R8 (or maybe R10?) have been standalone software that should work with any QuickTime app. If that doesn’t work for you, you can export clips into any QuickTime codec with “Export from edit suite.” If that’s too painful, consider buying the latest rev of Producer. The 14 day trial version is free.
James Kirk
July 16, 2007 at 12:16 pmThese files are from version 6 of Media 100.
I’ll try Producer sw and see if it can export as a Quicktime.
Thanks for the help. -
Scott Lindgren
July 16, 2007 at 3:28 pmInstall the media 100 transcoder into your Quicktime pro library. Create a reference file in Media 100. Open the Media 100 reference file in quicktime pro and export. Not sure if this works with Pro Res but it works great for all SD quicktime!!!
David Colantuoni
July 17, 2007 at 1:06 pmDude, version 6 of Media 100! Wow, we need to get people upgraded, version 6 is from 8 years ago. Sounds like you could use the Producer upgrade to me and make this easier for you. Think about it.
Dave
David Bogie
July 17, 2007 at 3:41 pm[scott lindgren] “nstall the media 100 transcoder into your Quicktime pro library. Create a reference file in Media 100. Open the Media 100 reference file in quicktime pro and export. Not sure if this works with Pro Res but it works great for all SD quicktime!!!”
Where does one find this mysteriously elusive trancoder these days?
I’ve got a bunch of M100 files form 2001 and before that I should like to bring into FCP but my old transcoder software only works in OS9.
bogiesan
Andrew Mehta
July 18, 2007 at 3:48 pmHi, I think I answered this in the other thread. The OSX transcoder, the OS9 transcoder, and the new OSX Codecs can all be downloaded from the Media100 website.
OS9 Transcoder:
https://www.support.media100.com/KBSearch/kbDocument.aspx?id=181OSX Transcoder:
https://www.support.media100.com/KBSearch/kbDocument.aspx?id=193New OSX Codecs (which replace the transcoder):
https://www.support.media100.com/KBSearch/kbDocument.aspx?id=379I believe all of these are PowerPC only.
For Intel, you’d either want to run the PPC ones under rosetta, or else use the latest Media100 software trials.
