Activity › Forums › Apple Final Cut Pro Legacy › Convert large HD file to under 2 GB
  • Convert large HD file to under 2 GB
    Posted by Bobby Hall on August 23, 2013 at 5:37 am
    I have an 18 minute short that I want to submit online to a festival that requires the video to be under 2 GB. Right now, it’s 18 GB, 1920×1080 prores 422. I’ve tried different ways to get it under 2 GB, but I can’t seem to do it. I’d like it to be 1280×720 and look really good. How can I do this is mpeg streamclip?
    Bobby Hall replied 13 years, 1 month ago 4 Members · 4 Replies
  • Spencer Averick
    August 23, 2013 at 9:05 am
    Set the video codec to H.264, change the data rate to 2500 and you can keep it at 1280×720.
  • Neil Patience
    August 23, 2013 at 5:38 pm
    Spencers suggestion is a good one. In MPEG streamclip there are some presets for Apple TV which are H264 MP4. Never had an issue with quality or PC/Mac compatibility.
    There is a 720 preset and I have always found these to be good quality conversions at a reasonable bit rate. Basically its pretty much the same quality as you would get from a movie downloaded from iTunes.
    Hope thats helpful.
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
  • Jacob Brown
    August 23, 2013 at 5:44 pm
    If you are using compressor or something like that, be sure to pay attention to the key frame setting in the H264 conversion.
    If you have a lot of fades or composites or effects or the like. Or rapid camera movements. Or a few other things….then you will want to do a keyframe every few frames. Otherwise you can get weird compression artifacts.
    It’s basically a keyframe every X number of frames. Lower that number is higher quality, bigger file size. So just play with it until you like the output and file size.
  • Bobby Hall
    August 24, 2013 at 12:01 am
    Thanks guys.
    I played around with the bit rate settings in MPEG streamclip and got the video under 2GB with the bit rate set at 6,000 kbps.
