Activity Forums Adobe After Effects Expressions convert image to binary code Scripting
  • convert image to binary code Scripting
    Posted by Rainier Raydán on March 6, 2018 at 2:55 pm
    Hi guys!
    I’m trying to add an png image to my script and I do it with this method:
    res = "group{orientation:'column', alignment:['fill', 'fill'], alignChildren:['fill', 'fill'],\
    myMooco: Group{ orientation:'row', alignment:['right', 'fill'],\
    var moocoImg = File ("./MOOCO_LOGO_Script.png");
    var icon = myPanel.grp.myMooco.add ('image', undefined, moocoImg);
    It works fine but I have problems launching it with the adobe extendscript toolkit CC (if I do it via file+script+runscript it works fine). When I push the play button it gives me the error “invalid image data ” from this line:
    I supose it doesnt find the image for some reason. Anyway, is there a way to convert images to binary code so I can write that code to mi file and avoid inserting the png file?
    Rainier Raydán replied 8 years, 5 months ago 1 Member · 1 Reply
  • Rainier Raydán
    March 6, 2018 at 4:12 pm
    I’ve find a way!
    Using this incredible script: https://aescripts.com/file-to-binary-converter/
    You can convert the png file to a binary string.
    just copy all the code between the quotes (dont copy the (new String() ) and paste it inside a variable, then use it to embed it.
    var binaryIcon= PASTE CODE HERE ;
    var myIcon = myPanel.grp.myGroup.add ('image', undefined, binaryIcon);
    Bye!
