Activity › Forums › Apple Final Cut Pro Legacy › Convert HDV 50i to HD 24p
  • Convert HDV 50i to HD 24p
    Posted by Janwess on August 6, 2005 at 10:14 pm
    I tried to convert HDV 50i project to HD 1080p with 24p and 23,98p but the result is bad.
    Which is the best way to convert 50i to 24p or 23.98p?
    Final Cut Pro 5
    OS x Tiger
    Dual 2,5 Ghz
    DeckLink HD Pro
    Juan Salvo replied 21 years, 1 month ago 3 Members · 3 Replies
  • Shane Ross
    August 7, 2005 at 12:59 am
    First you need to use a Standards converter to convert the PAL footage (50i) ot NTSC (60i)…like the Standardds Converter from http://www.nattress.com ($100). Then you can reverse telecine the footage to 23.98.
    But by then it might look very jittery…
  • Juan Salvo
    August 7, 2005 at 10:27 pm
    Export an image sequence… reimport the image sequence @ 24fps timebase. Slow down your audio 4% to match (do a pitch adjustment in protools or some audio program… not sure if soundtrack pro does this).
  • Juan Salvo
    August 7, 2005 at 10:28 pm
    You’ll also need to deinterlace.
