Thanks – I converted all clips, re-loaded one and it’s still stuttering during playback, which makes editing difficult.
Not sure what I’m doing wrong.
e.g. I put a mov clip on the timeline, pres the space bar to play it. It plays, then near the end skips.
I’ve tried 3 different settings under RT
Full Quality, Use Playback Settings and Play Base Layer Only
Footage:
MOV
Compression: None
1280×720
Mac Pro – OS X Leopard
***UPDATE***
I changed the None compression to ProRes 422, and made sure that the sequence in FCP was ProRes 422. This seems to work with one small clip, meaning that now, the clip plays back smoothly and exports smoothly.
I’m going to re-export the other clips the same way.
