Activity Forums Adobe After Effects Expressions Convert Expressions to Keyframes
  • Convert Expressions to Keyframes
    Posted by Roger Averdahl on December 22, 2006 at 8:05 pm
    Hi!
    I have applyed a Animation Preset named Ocean Tide to a couple of textlayers and adjusted it so the text just slightly moves.
    It renders very slowly so i tried to convert the expression to keyframes to see if the render time improves. I pressed E+E and selected Amount and then went to Animation > Keyframe Assistant > Convert Expressions to Keyframes. AE does not convert the expression to any motion, the text stays in a static positon, so my cuestion is if all expressions can be converted to keyframes. It seems that only some expressions can be converted to keyframes. Am i right?
    I have tried to convert a simple expression (Random) to keyframes and it worked like a charm.
    I am using AE7.
    /Roger
    Roger Averdahl replied 19 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 25, 2006 at 10:55 pm
    I think you unfortunately stumbled onto a special case (the expression applied to an expression selector). Convert Expression to Keyframes does not seem to work for it the way it does for other expressions.
    Dan
  • Roger Averdahl
    December 26, 2006 at 11:33 am
    O.k!
    Thanks for your answer Dan! 🙂
    /Roger
