Activity Forums Adobe After Effects Expressions convert expressions to keyframes CS3
  • convert expressions to keyframes CS3
    Posted by Darren Hardaway on June 7, 2009 at 10:39 pm
    Hi, I have been trying to find a way to convert effect expressions to keyframes. I’m not sure if it will speed things up, but I pretty much tore my proccessor apart trying to preview this comp and I thought maybe if the values were held with keyframes it won’t have do as much work. I’m working with radio waves an a preset to interpret audio using Audio Spectrum. Any help with this would be great. Thanks!
    Darren Hardaway replied 17 years, 3 months ago 2 Members · 2 Replies
  • Todd Kopriva
    June 7, 2009 at 11:26 pm
    Did you try the Convert Expression To Keyframes command?
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Darren Hardaway
    June 8, 2009 at 3:46 am
    hehehe, its funny how if you click the layer itself you can get into the keyframe assistant tab but not when you click on a parameter. Thanks for the tip tho, didn’t think to look there.
