Activity Forums Apple Final Cut Pro Legacy Convert DVCPRO to ProRes within FCP
  • Convert DVCPRO to ProRes within FCP
    Posted by Olaf Steel on November 13, 2012 at 12:54 am
    I’m setting up a large project in FCP. There is footage I need to create multicam clips with. However, the footage in FCP is DVCPRO and ProRes 422. FCP wont let me make multiclips with the different formats.
    Having already imported 50+ hours of footage, and taken up over 8TB of hard drive space, is there any way to quickly/easily/using as little hard drive space as possible, convert the DVCPRO footage to ProRes 422? Preferably within FCP using the Media Manager tool?
    I would greatly appreciate any help with this.
    Olaf Steel replied 13 years, 10 months ago 3 Members · 5 Replies
  • Olaf Steel
    November 13, 2012 at 1:09 am
    Also worth noting is that I will want to relink to the original raw media when the project has been edited. So I need a way to do the above, while keeping the original metadata intact.
  • Rafael Amador
    November 13, 2012 at 1:11 am
    [olaf steel] “is there any way to quickly/easily/using as little hard drive space as possible, convert the DVCPRO footage to ProRes 422? Preferably within FCP using the Media Manager tool?”
    Lie all the DVCPro stuff on sequences and use MM.
    I would better try MPGStreamclip batch export. Will keep the original file names.
    rafael
    http://www.nagavideo.com
  • Rafael Amador
    November 13, 2012 at 1:25 am
    [olaf steel] “Also worth noting is that I will want to relink to the original raw media when the project has been edited. So I need a way to do the above, while keeping the original metadata intact.”
    Will your multicam project allow you to re-link to a footage with different specs?
    rafael
  • Nick Meyers
    November 13, 2012 at 9:51 am
    in FCP, you can use Media Manger on a bin or sequence of the clips.
    OR
    in FCP you can Batch Export as QuickTime Movie, and change the settings on export
    both will keep File name, TC & Reel#
    we are all assuming you have the same FRAME RATE on both sets of media
    cheers,
    nick
  • Olaf Steel
    November 13, 2012 at 3:13 pm
    Thanks for that Nick. I do indeed have the same frame rates.
    Right now I’m doing a batch Media Manager conversion. I’ll do a test later to make sure it worked. Thank you for your help!
