Activity › Forums › Apple Final Cut Pro Legacy › convert DVCPro HD QT file for “regular” QT on PC?
  • convert DVCPro HD QT file for “regular” QT on PC?
    Posted by J. Tad newberry on March 17, 2009 at 5:09 am
    I captured an hour of HDV footage with the DVCPro HD 1080i 60 codec. These QT’s play nicely on my Mac G5 in Quicktime, but not on my PC (neither with Vista nor XP). Is there a codec to use to convert these files to something viewable (and still in “HD”) on a PC?
    Thanks again!
    J. Tad Newberry
    Big Ya Productions
    Power Mac G5
    Dual 2 GHz
    http://www.bigya.tv
    Arnie Schlissel replied 17 years, 6 months ago 5 Members · 6 Replies
  • David Roth weiss
    March 17, 2009 at 5:21 am
    Ah, the former Mortimer Heathcliff. Finally out from behind the mask I see…
    You have two options:
    1. Buy the rather expensive XD Decode app available at https://www.calibratedsoftware.com/QXD.asp.
    or
    2. Transcode to ProRes and use the free Apple ProRes Decoder for Windows.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Michael Sacci
    March 17, 2009 at 5:27 am
    Raylight has a slightly more expensive decoder for DVCProHD for windows, but it also has an encoder also. These would be worth it if you needed to do this a lot to save transcoding time.
  • J. Tad newberry
    March 17, 2009 at 7:14 am
    Yes, it is. Fully “unmasked” for several months now. Thanks again for your solutions. It hit me about half-way through burning these QT’s to DVD that they probably weren’t going to play in my PC (not good for sending to a client). As per your input, I converted one file to Pro Res, and it multiplied it’s size about 7 fold. In the future, if you were capturing HDV footage, and wanted to also send “full rez” clips to the client for possible future use on a PC system, what codec would be best to use? I had forgot that DVCPro HD is a unique codec to FCP…but hopefully will remember next time!
    Thanks again!
    J. Tad Newberry
    Big Ya Productions
    Power Mac G5
    Dual 2 GHz
    http://www.bigya.tv
  • David Roth weiss
    March 17, 2009 at 8:30 am
    [J. Tad Newberry] “In the future, if you were capturing HDV footage, and wanted to also send “full rez” clips to the client for possible future use on a PC system, what codec would be best to use?”
    That’s a bit of issue, as you’ve seen. I think the ticket is to send ProRes files on a firewire drive for them to offload.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Michael Hancock
    March 17, 2009 at 1:24 pm
    You could also download the Avid codecs. If you compress to their DV100 codec it should keep about the same file size as your DVCProHD files. Then burn the installer to the disk and tell your client to run the installer first, then watch the quicktimes.
    Get the Avid codecs here:
    Avid Codecs
    Michael
  • Arnie Schlissel
    March 17, 2009 at 3:05 pm
    You could always try Photo-JPEG at 50%. I’ve had a very good experience using that for many purposes. Just remember to stretch it back out to full raster for export.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
