Activity › Forums › Adobe Premiere Pro › Convert DPX images to QuickTime
Posted by Frank Giardina on November 14, 2012 at 9:36 pmHi All…
A friend of mine has DPX files he wants to have converted to QuickTime. Does anyone know of a workflow for this?
Frank Giardina
17 Video ProductionFrank Giardina replied 13 years, 9 months ago 4 Members · 9 Replies -
Angelo Lorenzo
November 14, 2012 at 9:53 pmFile > Import > Select your DPX sequence and tick “image sequence” in the file select box. Add the soundtrack files as appropriate (DPX does not store audio) and export to whatever Quicktime codec you need to deliver. I would assume you’re doing it for a specific purpose so there should be delivery specs like what size, codec, quality and so on.
Seems simple enough. Or are we missing some part of the story that makes it more complicated than face value?
Quicktime is simply a container, so without knowing the purpose for the delivered file, no one can give you an export suggestion if that is also what you’re asking.
Angelo Lorenzo
Love my answer? Do me a huge favor and check out my Kickstarter project The Librarian, starring Jennie Garth of Beverly Hills 90210.
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks -
Frank Giardina
November 14, 2012 at 10:39 pmThanks Angelo!
There’s not much more to the story really… at least that I know of. He’s writing the files to dvd and sending them to me. I told him I was pretty sure I could export to QuickTime for him. He’s using them in a montage that consists of a mix of stills and video. With that being said… audio is not a concern.
I appreciate your workflow a lot!
Thanks Again!!
Frank Giardina
17 Video Production -
Frank Giardina
November 15, 2012 at 2:12 amThanks Angelo!
Frank Giardina
Frank Giardina
November 15, 2012 at 2:14 amAngelo… the Librarian looks awesome!
Frank Giardina
Tero Ahlfors
November 15, 2012 at 7:39 amYou can also bring image sequences in Adobe Media Encoder.
Bill Stephan
November 15, 2012 at 9:28 pmAja has a software utility for DPX-to-Quicktime conversion. After Effects will also do it by importing the DPX sequence and exporting whatever file format you need. There are also other DPX utilities for Mac.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City -
Frank Giardina
December 11, 2012 at 8:52 pmHi Everyone…
I finally have the DPX files. I imported them into PR CS6… brought them into a sequence, but it looks like each DPX folder is like 120frames, at least that’s what happens in the timeline.
This is a bit confusing. When I do an export and scrum through the view it looks OK, but the quicktime is not good.
any thoughts or suggestions?
Frank Giardina
Frank Giardina
December 12, 2012 at 1:02 amAlso… each DPX is like 5 seconds long in the timeline … I exported the sequence using a few different setting and each time the same results. This is weird.
Frank Giardina
Frank Giardina
December 12, 2012 at 4:39 amWell, I worked out using AE, but the quicktime seem to be a bid sped up. Any thoughts on that?
Frank Giardina
17 Video Production
