Activity Forums Apple Final Cut Pro Convert DNxHD in MXF wrapper to ProRes
  • Convert DNxHD in MXF wrapper to ProRes
    Posted by Rich Hawksworth on May 21, 2014 at 6:46 pm
    I was given a DNxHD file in an MXF wrapper and need to work with it in FCPX. Is converting it to ProRes my best option and, if it is, what’s the best way to do it.
    Darren Roark replied 12 years, 3 months ago 3 Members · 4 Replies
  • Helge Tjelta
    May 21, 2014 at 7:34 pm
    I would just download BlackMagic DaVinci Resolve, import all the mxf, put them into a timeline, render all out again as prores.
    It’s free and can work as a great converting hub. And also later as you coloring stage as well
    Helge
  • Darren Roark
    May 21, 2014 at 7:38 pm
    That is one option, you can also rewrap the mxf files to quicktime without transcoding if you have the Avid QT codecs installed.
    The expensive/best way is with the Hamburg MXF import plugin, you don’t even have to rewrap the MXF files, it handles them natively. It’s around $300, but if you are going to be doing a lot of work with DNxHD files it’s a great tool to have.
  • Rich Hawksworth
    May 22, 2014 at 4:30 pm
    Maybe a dumb question, but how do I rewrap the files? That seems like the best option for my situation.
  • Darren Roark
    May 22, 2014 at 9:02 pm
    https://www.divergentmedia.com/clipwrap
    Clipwrap is a pretty handy thing to have around.
