Activity Forums Adobe Illustrator convert compound paths to seperate layers
  • convert compound paths to seperate layers
    Posted by Joel Arvidsson on September 21, 2010 at 1:20 pm
    Hi Is it possible to select serval compound path layers and convert then to separate layers? Say you have a layer that contains alot of compounded pathen you want to bring into After Effect and be able to animate all compounded pathes indivually. I guess theres a simplier workflow than create a new layer and drag and drop a compounded path to that. Then keep doing this to all compounded pathes have their own layer.
    joelarvidsson@gmail.com
    Joel Arvidsson replied 16 years ago 2 Members · 2 Replies
  • Les Nemeth
    September 21, 2010 at 9:45 pm
    Select (hilite) the layer, click palette menu > release to layers (sequence)
  • Joel Arvidsson
    September 22, 2010 at 8:20 am
    Thanks les nemeth! This saves alot of time waste that can be to into the creative process instead.
