Activity › Forums › Maxon Cinema 4D › Convert C4D R11 to C4D 2024
  • Kouraib Abdmalek
    May 1, 2025 at 7:29 am
    Hi Ulli,
    I tried converting it but it didn’t work, I’m afraid it’s built on an older version than R11.
  • Oliver Turner
    May 16, 2025 at 12:05 am
    That’s frustrating! If the file is older than R11, it might be trickier to convert directly. Have you tried opening it in an intermediate version like R15 or R20 first, then saving it for C4D 2024? Sometimes stepping through versions helps. Also, check if the file has any legacy plugins that might be causing issues.
