Activity Forums Apple Final Cut Pro Legacy Convert back to PAL
  • Convert back to PAL
    Posted by Nicolas 24 on August 4, 2005 at 11:42 am
    I know now what I did.
    Digitized PAL cause cam is PAL. FCP converted it to NTSC cause so was the setting and now cam being PAL and footage NTSC it wouldn’t play out properly.
    Can I convert my NTSC to PAL (so that I can play out to my cam?) or,
    Do I need and NTSC deck to play out to?
    Many thanks!
    Kathy replied 21 years, 1 month ago 2 Members · 1 Reply
  • Kathy
    August 5, 2005 at 9:04 am
    You have to convert back to PAL to play out to your camera but why don’t you just change your settings to PAL (easy setup), make your clips offline and then recapture them at the correct settings?
    Kathy
